Can't change default launcher Z69
I have the Z69 3gb/32GB amlogic s905x. I do not like the look of the launcher on this box I really want to use Nova Launcher but when I run it I get an error which which which will be let me see below. I tried numerous other launchers and all have gotten the same result. is there a ROM of there that I can use that will fix this or is there something that I can just do in the Box itself?
You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoPlease take the time visit my fundraising page for an accessible wheelchair van.
Click here to support my wheelchair accessible van fundraiser.
https://i.imgur.com/pldcvD6.jpg?1https://i.imgur.com/PaM4GAy.png?1Tags: None
Originally posted by Repoman View PostI have the Z69 3gb/32GB amlogic s905x. I do not like the look of the launcher on this box I really want to use Nova Launcher but when I run it I get an error which which which will be let me see below. I tried numerous other launchers and all have gotten the same result. is there a ROM of there that I can use that will fix this or is there something that I can just do in the Box itself?
do you have "root" , did you try to install the Launcher as SystemApp , some Launchers have inside Settings ??? ,
even if you press "always" ???, good luck / gefattern
There are currently 2669 users online. 1 members and 2668 guests.
