MK908II Hybrid Firmware (HFW) + debloted, rooted stock firmware by lewy20041
    Originally posted by sakal View Post
    which one new ROM?
    this one http://blog.geekbuying.com/index.php...d-tv-launcher/ says video playback issue's are fix.. cant try it yet coz still waiting for my order to arrive
      Update tips for MK908II. (Not Mk 908)
      Fb page
      https://www.facebook.com/pages/Mk-90...88763897980449
        Originally posted by Bazmamfoo View Post
        No but there is another thread for that device
        Sent from my GT-I9505 using Tapatalk
        can you give me the link of the thread? i cant find it
          Won't reboot after flash.
          Anyone have problems booting the device after completing this flash? I've flashed it twice and it never reboots.
          Here is the log;
          19:01:11 384 Rockchip Batch Tool v1.7.1.1 start run
          19:04:24 222 **********Restore Start Total<1>**********
          19:04:24 222 <Layer 1-1-2> Test Device Start
          19:04:24 222 <Layer 1-1-2> Test Device Success
          19:04:24 238 <Layer 1-1-2> Lowerformat Device Start
          19:04:25 254 <Layer 1-1-2> Lowerformat Device Success
          19:04:25 254 <Layer 1-1-2> Test Device Start
          19:04:25 254 <Layer 1-1-2> Test Device Success
          19:04:25 254 <Layer 1-1-2> Check Chip Start
          19:04:25 254 <Layer 1-1-2> Check Chip Success
          19:04:25 254 <Layer 1-1-2> Get FlashInfo Start
          19:04:25 254 <LAYER 1-1-2> INFO:FlashInfo: 0 8 E7 0 0 4 4 0 28 0 1
          19:04:25 254 <Layer 1-1-2> Get FlashInfo Success
          19:04:25 660 <Layer 1-1-2> Prepare IDB Start
          19:04:25 660 <LAYER 1-1-2> INFO:CS(1) (7393MB) (SAMSUNG)
          19:04:25 675 <Layer 1-1-2> Prepare IDB Success
          19:04:25 675 <Layer 1-1-2> Download IDB Start
          19:04:26 035 <Layer 1-1-2> Download IDB Success
          19:04:26 035 <Layer 1-1-2> Reset Device Start
          19:04:27 043 <Layer 1-1-2> Reset Device Success
          19:04:27 046 <Layer 1-1-2> Wait For Loader Start
          19:04:29 724 <Layer 1-1-2> Wait For Loader Success
          19:04:29 727 <Layer 1-1-2> Test Device Start
          19:04:29 731 <Layer 1-1-2> Test Device Success
          19:04:29 733 <Layer 1-1-2> Download Firmware Start
          19:06:47 967 <Layer 1-1-2> Download Firmware Success
          19:06:47 967 <Layer 1-1-2> Reset Device Start
          19:06:48 980 <Layer 1-1-2> Reset Device Success
          19:06:48 983 **********Restore Done Success<1> Fail<0> Time<144766>ms**********
          19:11:49 805 Rockchip Batch Tool v1.7.1.1 start run
          19:12:08 884 **********Restore Start Total<1>**********
          19:12:09 025 <Layer 1-1-2> Test Device Start
          19:12:09 025 <Layer 1-1-2> Test Device Success
          19:12:09 025 <Layer 1-1-2> Lowerformat Device Start
          19:12:10 040 <Layer 1-1-2> Lowerformat Device Success
          19:12:10 040 <Layer 1-1-2> Test Device Start
          19:12:10 040 <Layer 1-1-2> Test Device Success
          19:12:10 040 <Layer 1-1-2> Check Chip Start
          19:12:10 040 <Layer 1-1-2> Check Chip Success
          19:12:10 040 <Layer 1-1-2> Get FlashInfo Start
          19:12:10 040 <LAYER 1-1-2> INFO:FlashInfo: 0 8 E7 0 0 4 4 0 28 0 1
          19:12:10 056 <Layer 1-1-2> Get FlashInfo Success
          19:12:10 556 <Layer 1-1-2> Prepare IDB Start
          19:12:10 556 <LAYER 1-1-2> INFO:CS(1) (7393MB) (SAMSUNG)
          19:12:10 556 <Layer 1-1-2> Prepare IDB Success
          19:12:10 572 <Layer 1-1-2> Download IDB Start
          19:12:10 947 <Layer 1-1-2> Download IDB Success
          19:12:10 947 <Layer 1-1-2> Reset Device Start
          19:12:11 958 <Layer 1-1-2> Reset Device Success
          19:12:11 962 <Layer 1-1-2> Wait For Loader Start
          19:12:14 620 <Layer 1-1-2> Wait For Loader Success
          19:12:14 623 <Layer 1-1-2> Test Device Start
          19:12:14 626 <Layer 1-1-2> Test Device Success
          19:12:14 629 <Layer 1-1-2> Download Firmware Start
          19:14:32 575 <Layer 1-1-2> Download Firmware Success
          19:14:32 575 <Layer 1-1-2> Reset Device Start
          19:14:33 594 <Layer 1-1-2> Reset Device Success
          19:14:33 597 **********Restore Done Success<1> Fail<0> Time<144718>ms**********
            I have the same problem, after flash the device will not boot.
            Sofar the only FW that works on my device is Stock, too bad it's crap, was really hoping on a good custom firmware.
            Any ideas what could cause the problem?
              hi lewy, just got my device, any idea, why my device keeps rebooting? and sometimes after reboot, the wizard screen appears again but i still have all my apps..
                please try difrent power source.
                sometimes stock power adapters are the couse.
                Everything is possible if we work together!
                ApkFreak
                  thanks lewy, just wanna ask is your rom base on the latest update? i have a 2A power charger for my galaxy note 10.1, would that be enough?
                    It should be ok. Try it and post back if reboots still ocure.
                    ApkFreak
                      Re: MK908II Hybrid Firmware (HFW) + debloted, rooted stock firmware by lewy20041
                      Try a different cable, I was having the same problem and a cable fixed the issue.
                        thanks lewy and baz for helping me.. i hope this will fix the problem..
                          2.0.3 do not boot also on my MK908II. I have two different power adapters and still nothing. HDMI cable is good, because Finles ROM works on it fine.
                          Damn it
                            2.0.3 and 2.0.2 not boot on MK908II from geekbuying. I have black screen on my TV.
                            Finless ROM 1.5a works OK.
                              This rom not boot on mk908II. Please, update is required.
                                hi lewy, how do i know if my charger or PSU is giving out the right Amp? is there an app that does this? thanks
