Argh! I found a reason why I have app issues.
For some reason some apps won't have any permissions set when Installed. Not sure if It is the apk managers I use, or downloaded apps installed by Solid Explorer Pro, or something about Magisk 16.0. I had to set permissions over 60% of my installed apps. So, now now I will have to check each app after install to see if any permissions get set and make adjustments if needed. Hopefully it is not a device issue, so identifying what causes the condition, can be circumvented once the issue can found.Tags: None
Originally posted by neomode View PostHello,
Why you install your Apps with Solid Explorer Pro?
Use APK installer that comes with the rom instead.
I think that will solve your Problem.
Neomode
found a fix on the Internet... just reinstall the apps through normal means to correct. Don't use 3rd party installers.
There are currently 3031 users online. 0 members and 3031 guests.
