H96 MAX Plus RK3328 Android 8.1 4/32 TV BOX YT 4K WiFi LAN USB3.0
    H96 MAX+ RK3328 Android 8.1 4GB/32GB KODI 17.6 4K TV BOX Support YouTube 4K WiFi LAN USB3.0 H.265 Decoding
    Click image for larger version  Name:	geekbuying-H96-MAX--RK3328-Android-8-1-4GB-32GB-TV-BOX--589635-.jpg Views:	1 Size:	172.4 KB ID:	741380
    Specification
    General Model: H96 MAX+
    Type: TV Box
    Hardware OS: Android 8.1
    CPU: RK3328 Quad-Core 64bit Cortex-A53
    GPU: Penta-Core Mali-450 Up to 750Mhz+
    RAM: 4GB DDR3
    ROM: 32GB eMMC
    Communication WIFI: 2.4G WIFI
    LAN: 100M
    Media Support Decoder format:4K VP9 Video decoder, H.265/H.264 video decoder
    1080P other video decoders (VC-1, MPEG-1/2/4, VP6/8)
    Support Media format: Avi/Ts/Vob/Mkv/Mov/ISO/wmv/asf/flv/dat/mpg/mpeg
    Support Music format: MP3/WMA/AAC/WAV/OGG/DDP/HD/FLAC/APE
    Support Photo format: HD JPEG/BMP/GIF/PNG/TIFF
    HDR: HDR10 and HLG modes
    High Definition video output: 4K (4096x2160 pixel )
    Interface AV,HDMI 2.0, RJ-45,Card reader, USB3.0,USB2.0
    Other Features KODI 17.6
    Certification: CE,FCC,ROHS
    OSD type of languages: English/French/German/Spanish/Italian/ etc multilateral languages
    HDD file system: FAT16/FAT32/NTFS
    Support Subtitle: SRT/SMI/SUB/SSA/IDX+USB
    Support Neflix,Vudu,Skype chatting,Picasa,Flicker,Youtube,Facebook,Online movies,etc
    Other features: Free Internet searching,thousands of android applications,many kinds of games,etc.
    Power DC 5V/2A
    Power Indicator Power ON: blue
    Package Contents 1x TV BOX
    1x IR Remote Control
    1x HDMI Cable
    1x Power Adapter
    1x User Manual
    Geekbuying
    Last edited by trebor; 15 October 2018, 01:34. Reason: Removal of Netflix HD as reflected by Geekbuyings Link
    Today thanks to Geekbuying
    We can have a closer look at the
    I note also the Removal of Netflix from the Geekbuying Add
    So the Claims of this unit are as found
    Runs on Android 8.1
    H96 MAX+ is at the moment one of the first TV Boxes which runs on Android 8.1 an update to Oreo that showcases more ways to express yourself, along with a handful of other sweet features and improvements to stability as well as performance.
    Loaded with Rockchip RK3328
    H96 MAX+ is one of the first models that comes equipped with Rockchip RK3328, the latest Rockchip SoC unveiled in the Janurary CES. With the latest RK3328 SoC loaded, H96 MAX+ will be able to play 4K videos with H.265, H.264 and VP9 codecs, other than that, it features HDR, HDMI 2.0, USB 3.0 to say a few.
    4GB RAM, eMMC 32GB
    It boasts 4GB RAM, and eMMC 32GB, advantageous in performance, security and reliability, ascribing to the eMMC memory, ultimately delivering a richer end-user experience.
    HDMI 2.0 Connector
    You can go directly to let your TV and H96 MAX+ TV Box are connected through an HDMI cable and set up your home cinema for the best 4K x 2K UHD multimedia experience.
    True 4K Media Player
    While your average media box might only accept 1080P video playback, this gadget plays just about any 4K sources you could throw at it. Furthermore, it moves out into reality the fantasy of VP9 hardware decoding alongside the H.265.
    Lets start with a couple of Pictures busy this day a slow produce on this
    The Box
    Ports
    Remove Base,
    Out with PCB larger heat sink than normal.
    Closer look topside
      New Firmware as found,
      http://geekbuying.mediafire.com/file...181008.7z/file
      RK3328_H96_MAX+_SSV6051_RTL8189_8.1.0_20181008.225 8
      Source Blog.geekbuying
      Hope to test the this unit later this day, before updating
        Did a few screenshots etc startup all good...pretty zippy as it is
        Netflix only 480p,
        has root with SU installed, looking ok
        Thought I would attempt the rom above rom as the one installed dated August 2018 what could go wrong...
        Now If i can only get the box to detect, Fails even as a usb device plugged in, many cables, ports and PCs, drops recovery and that's about so far..
        More if it can happen...
        Startup Wizard
        UI and Installed Apps
        System Info
        Moresettings
        Much the same, no extra features found In Display, or Dev options,
        Maybe the update will have the goodies....if we can get it to detect
          So if all else fails, I guess we RYFM
          And there it is,...
          Run tool load rom click burn.
          Remove all cables etc,
          Hold Reset while plugging in USB 2 port and away it goes
          Been awhile since i have burned a RK box as we know it
          A quick look around all the same, as far as I can see, same apps, no hidden features as yet..
          Info
          Info
          Storage
          Root
            On with a bit more on the H96 MAX Plus RK3328 Android 8.1 4/32 TV BOX YT 4K WiFi LAN USB3.0
            New rom Installed as mentioned did not see a lot of difference software wise
            Rom working pretty well using 8.1 if that is the case
            Netflix 480 as mentioned that, watchable Prime Video Good and Plex
            Box does pretty much as expected, for the Price.
            Remote Ok for what it is all works no extra feature in remote as yet found
            Temps a little warm lack of vents etc 70~80c
            DRM Info
            Ram speed, appears a bit ordinary could be an 8.1 thing
            CPU-Z x 4 slides.
            Ram and Storage Truth
            GeekBench
            Prime Video
            Ethernet
            Old Rocket cleaner looking a bit of a square well rectangle
            Aida64 7 Frames
            App button on remote shows apps,
            and by the looks so YT cant play 4k video as also mentioned
