Alfawise H96 Pro after successful burning ROM - not working - SOLVED
    Hi Everyone,
    I have bought 2 Tvbox Alfawise H96 Pro from GearBest.
    Both bricked after one day of use.
    I have installed few ROM,s, using USB Burning Tool 2.0.8 but after successfully burning the devices still not working.
    On first of them the LED flashing RED. On the second one thr LED flashing violet.
    I have tried many ROMS:
    From Gearbest:
    aml_s912_q6330-h96pro-mac-20160918
    aml_7.1_s912_q9377-H96PRO-KDMC_mac-20170619
    aml_s912_q9377-H96ProPlus(3+32_kodi16)_mac-20170406
    From FreakTab:
    SCV4-A7.1.2-x64-Alfawise.H96.ProPlus
    SCV4-Test1-Blue-PCB-H96ProPlus
    From mega.nz
    Winsdom:
    aml_7.1_s912_q9377-H96PROPLUS-KDMC_mac-20170619
    s912_q9377-H96_KDMC17.3_50ME_600M_mac-20170918
    aml_7.1.2_s912_q9377-S912_mac-20170908
    aml_7.1.1_s912_q9377-H96PROPLUS_mac-20170422
    After burning the LED still blinking the same color or no light it depends of ROM. After connecting to TV via HDMI I couldn't see anything.
    1st. Device:
    2017-08-23 ( green) RED LED blinking
    ZH01 V2
    2dn. device
    2017-02-10 VIOLET LED blinking
    H96 DDR4
    There are some chances to unbrick this devices?
    Mayby somebody smarter than me can say something?
    THANK YOU
    You may only view thumbnails in this gallery. This gallery has 5 photos.
    Wha? You flashed blue firmware on great boards! Not good
    you probably need to use the SD Card burning tool, and use a properly formated SD card.
      More than likely will have to Short the NAND chip and USB Burn Tool to flash factory firmware...maybe get away with flashing SCV4 Green...not sure.
        When I made flashing I shorted the NAND Chip and use USB burnig tool. All process was correct, but after that the devices still not working.
          If everything is OK on the PC and the box does not respond or shines red, the error is in the defective adapter.
          Try new adapter 5V / 2A or stronger 5V / 3A.
            I have the same 3 adapters 5V - 2,5 A. I can buy a new one stronger, but if i have tried 3 different it is low probability to success,
              Does the LED light stay on red or go dim or stay bright blue?
              Try a different T.V ..to see if HDMI Error.
              Or riskier let box boot up(60-120 secs. if light is bright blue) unplug HDMI cable and connect again...to see if T.V displays desktop. Potential risk of damage to HDMI Port on T.V. or China Box
                I do not mean to high jack your thread. But I have been looking for the firmware for H96 Pro + S32-v3 (ddr4) 2016-12-15 (A15).
                I found this firmware this Mega site, https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!Z6gTFC7A
                And I have tried several firmware for the model that I have. So far I can flash but the box does not boot. Any help, please.
                  My board is green and has the inscription LPDDR3, SO WHAT FIRMWARE OTA SCV7A DO I SHOULD USE?
                    here the link: https://www.entertainmentbox.com/new...ware-download/
                    good luck!
                      Gante THANK YOU VERY MUCH !
                      All 3 original power adapters were damaged. They did not give the right current Ampers despite the 5 V voltage (I checked with the multimeter).
                      I have bought new 5V/3A (connection model DC 2,1/5,5 mm, tuning fork) power supply and all devices are working properly with different ROMs.
                        You´re welcome.
