(ROM) Universal S912 AndroidTV V1.0
hi minixfreak
i will do installing my box with this [Universal S912 androidTv V1.0], but first to ask you: when i will install under [amlogic usb burning tool] will be format all partition..? because i want leave old android and add new androidTV (need 2 partitions) but bootloader set it default go to androidtv, if i want to see old android so add button or app (base) in androidtv for reboot direct old andorid..is it can do it?
example my computer has 3 parition: 1 partition linux and 2 partition windows and 3 partition ohter linux, but bootloader default is 1, if i need go to windows then open terminal and write:
Code:grub2-reboot 3 (windows) reboot
for installation [Universal S912 androidTv V1.0] there is partition manager for create 2 parts? and bootloader what is used from [Universal S912 androidTv V1.0]?
thank you minixfreak
There are currently 6462 users online. 0 members and 6462 guests.
