Also for some odd reason ATV play store is mixing phone apps in as updates to ATV apps. So when you update ESPN, FX Now, FOX Now, and others, you end up with tablet versions.
I assume he reason is because of another Google update with play store and play services.
I corrected some odd things with the google updates, by changing ATV into a Tablet/ATV hybrid. My ATV now has the ability to sync contacts, calender, people, and other Google stuffs in the account.
One interesting fix that I did not expect was, live channels now syncs play store without FC when adding more live content. I always was able to sync 120 or more live channels from Pluto, so I have no idea if it will help others who are limited to just 50.
Also HBO Go and VUDU now play audio through the ads... yes, DTS audio to boot! So, be sure to use the AVR remote, else you may blast your ears off.
will spend more time later in making ATV more tablet compatible, as it seems Dynamite and location services are now being slowly integrated into Smart TV apps. Looks like Google wants to track you to make sure you are where you are for its ad services. Thus locking in ads to your region.
