Freelander PD800 RileyROM 1.3 4.2.2
    Freelander has updated their PD800 firmware with Android 4.2.2!!!!
    This new ROM is based on the official firmware released on 9/6/2013.
    This ROM is:
    Rooted
    Debloated
    init.d support
    Busybox Support
    CWM Recovery (optional) the default is stock recovery
    Expanded Ext4 File System
    2, 4, 6, or 8gb user app space
    Boot screens by Tattman65
    Flash Tool by Finless
    First Time User's Guide by Pr0xZen
    Reboot app by Petrus
    Enjoy!!!!!!
    Download
    If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
    Randy
    flashed with cwm and parameter4
    while works
    had to format the 10GB partition as First, the system has not seen him
    mm.. google translator..
    antutu 18094
      If you are running CWM recovery, yes...you will need to format the internal SD...that is explained in the First Time User's Guide.
      Randy
        No Wifi
        I been using 1.2c, and was working nice, but the wifi, had cuts all the time.
        Some time before this update, when turn on wifi, the tablet got into bootloop, then had to go to a place where no wifi signals arround, set airplane mode, then usable, 'til wifi on agan, then bootloop.
        I updated to 1.3 4.2.2 and wifi doesnt turn on at all. Just a couple random times, got on but not worked for more that 5 minutes. The bluetooth work perfect. What can i do?
          Re: Freelander PD800 RileyROM 1.3 4.2.2
          Is anyone else having wifi problems? Or is this an isolated case?
          Randy
            I'm almost sure that im the only one, since i had wifi troubles before update...
            If its hardware, its possible to obtain the wifi module and change it?
            or im f**ked up then i should use USB ethernet adapter for the rest of the life?
              Sorry, I don't have much experience with Freelancer tablets...other than looking at the firmware. From the looks at the responses on my ROMS we aren't having much luck. I may have to defer development to someone who has one of these tablets to test on.
              Randy
                Freelander RileyROM 1.3.4.2.2.
                In Freelander PD800 Riley Rom 1.2 I wrote:
                In this time, after using the Rileyrom 1.2c for more than 2 weeks, I'm a very happy user.
                There is only one thing that I have to ask to the maker Randy.
                Using the wifi I have a very weak signal.
                Is it possible to give a boost or something else?
                Robert38
                Robert38.
                  Some of the Pipo tablets had the same problem, but there was inconsistency between devices. We found that the antenna wasn't soldered in correctly.
                  That may be the same flaw the Freelander tablets have.
                  It's either that, or a design flaw with the positioning of the antenna within the case.
                  Randy
                    Works great on my PD800! Faster and supports all apps. Voice recognition search works like a champ even in Hebrew.
                    I translated the instructions to Hebrew
                    Thanks for the good work!
                      Fantastic!!!!
                      I'm glad to hear some good results with these Freelander devices. I was about to give up, entirely.
                      Randy
                        freelander pd800
                        And may I ask you: how is your WIFI working?
                        Robert38.
                          Wifi is working just fine. note that this tablet does not excel at wifi reception... I have a sony xperia go phone that get's somewhat better distance from the router. It's ok that some devices are better than others by some measure. I didn't use the WiFi analyzer app to actually test the numbers though.
                            Works fine, very great! I installed the ROM in my tablet and...Man!, all work better than when I bought the tablet. It's like a new tablet. Great Job! I wish give you a donation for research and improve in new ROMS. My tablet now really work fine.
                            Thanks!
                              I'm glad to hear that. It took a while to get this ROM to work.
                              Thanks for your support!!!!!
                              Randy
                              Randy
