(ROM) ATVxperience S905
    (Rom) ATVxperience S905
    Beta
    -Based on wetek play 2 (Android 6.0)
    -A lot of wireless/bluetooth built in
    -Build Prop tweaks added
    -Preloaded with s95 remote.conf (can be changed)
    -Twrp 3.1.1 built in (Good for rooting or flashing remote patches)
    -Smooth video playing
    -Loaded with smartyoutubeTV (Regular youtube new updates has issues with Amlogic chipsets)
    To Do List
    -Add some system tweaks
    -add more visual ATVxperience icons etc
    Issues
    -You tell me
    Link: http://www.mediafire.com/file/iy28qj..._Beta_S905.img
    If you like team atvxperience work please donate as us, we work very hard for you guys
    we need funds to buy new devices to make more incredible firmware for you guys
    Nice start, but my Ethernet will not work on this port. WiFi works, but is too slow for any of my devices. This is the device I have, it is an Amlogic S905. If you can get the Ethernet port working, it will make a very nice port, especially going from Android 5.1 to 6.0.
      Please... somebody can share this rom...? is for try in my Troonsmart telos...?
      clarkss12 @minixfreak
        Apparently, Minixfreak removed the file..
          please Clarkss12, you have the rom in your files..? you can share with me via PM..?
            Is this ROM still going? and what board is it for and does it surpport Ap6330 WiFi chip?
              Will make this available in a few months
                Thanks,I updated my old S905(not w or X) box (Q-box 16gb 2gb ram) to 6.1 via ugoos AM2 ROM. and the ROM you are using has the AP6330 WiFi chip so hopefully when you get back to this ROM so I can use it.
                  This looks great! only link is dead.
                    Thank you for all your hard work.
                    Any update on the progress? A lot of Wetek Play 2 users really want to try this rom.
                    Keep up the great work
                      Here it goes https://forum.atvxperience.com/viewt...76#p3403:BACON
