I experienced CRC errors during copying so I wonder wether it was possible to insert SD into box and then connect box in MTP mode to pc?
Connect any box to PC in MTP mode? USB File Transfer mode?
Dear folks, I grabbed an micros SD which I formatted to FAT32 since it won't be accepted as exFAT.
Tags: None
Originally posted by soldiaz View PostUnderstand, right, often I see "charge". How can I change this?
Does ftp support crc check? I used wifi file transfer....
File transfer protocol has standard file checking. CRC check with SD card seems like a format issue or incompatible.
until you sort out your direct file transfer to SD card, any file to SD from network or USB will fail.
There are currently 2595 users online. 0 members and 2595 guests.
