New to FT - New to TV dongles - Guidance on how to..
    Hey guys.
    So i am new to FT and new to TV dongles.
    I have a H96 Pro 3gb / 16GB octa core dongle:
    H96 Pro S912
    Model: H96 Pro (q8723bs)
    CPU Architecture: AArch64 Processor rev 4
    Instruction set: arm64-v8a
    (Please let me know if i need more info).
    I am currently experiencing issues what feels like:
    Every time there is a large amount of wifi data to be transmitted, the signal drops out. Also the wifi connection seems to be excruciatingly slow.
    So i am considering flashing with a new ROM. From what i can tell the SuperCeleron rom seems to be the best reviewed.
    I have in the past rooted / fashed mobile phones but never a TV dongle.
    Are there any threads on here with instructions on how to:
    1. Back up the current rom
    2. Identify which rom you need
    3. Flash a custom rom?
    Thanks in advance
    Hello an welcome to FT.
    So for Flashing a new Firmware to your Device, you need the following things:
    1: USB A to A Cabel
    2: USB Burning Tool --> http://freaktab.org/ae9e49b4dc2c92d5
    Installing the USB Burning Tool install the needed Drivers also.
    But attention when using Windows 10 you have to Disable Driver verification!
    Burning How To is here --> https://drive.google.com/file/d/0ByE...ew?usp=sharing
    Backing up of the Orginal Rom is not needed there are Downloads of the Original Rom avail.
    Identify what Custom Rom to use is the best to Search with your Device Name.
    Then you will get a List of what you can use.
    Mostly you can Flash any S912 Rom to your Device without Brick it!
    Here is an archive with some of the
    Firmwares for your Device.
    Neomode
