Pipo has only produced one TV stick, and although I always wanted to do a ROM for it, I haven't until now because the firmware wasn't posted on the official Pipo site.
Thanks to user Kunar1, I was able to download a version of the firmware.
I don't have this TV Stick, so I haven't tested it. All I've done are the usual basics:
Root
Init.d support
Busybox support
Expanded Ext4 file system
2 or 4gb user app space choices
Boot animation art by Tattman65
Reboot app by Petrus
Flash Tool by Finless
First Time User's Guide by Pr0xZen
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
Randy Freaktab Developer, Product Reviewer, Moderator and "Flashaholic". Read my BIO Here
Be sure to donate to support Freaktab.com. If any of my development work makes a positive difference for you, please make a donation to support future RileyROM's. Donate here
I accidentally got this in the wrong forum...it's now moved to RK3066 devices.
Sorry for the delay...I've been thinking about this.
Since I don't physically have one of these sticks to look at.
Here's the usual sequence:
Read the First Time User's Guide PDF file included in the ROM kit. Follow the procedure to get the Rockchip drivers installed on your PC.
Once you have the driver installed, run the Flash Tool as Administrator.
Connect the USB cable to a USB 2.0 port on your PC.
There should be an external button on the TV Stick. Hold down that button while connecting the USB to the device. The Flash Tool should recognize the device in "Loader Mode".
First click the erase IDB button on the Flash Tool. Wait until it's done.
Then wait a few seconds and then click the Flash ROM button.
Once the device is flashed, it will reboot into recovery to format the partitions and it will then boot into the system.
