Beelink TV BOX screen capture function / remote control shortcut key instruction
    Screen capture functionand instructions for using the remote control shortcut keys
    Remote control screenshotand shortcut key setting instructions (applicable models and versions:GT1-708N0/708D0 version, GS1-105N0 version, A1-709N0 version)
    1.Remote control shortcut on/off
    Theshortcut key of the remote control is turned off by default after each brush isturned on. You need to open the shortcut and click the "# key".
    Itcan be turned on. In the middle, there will be a prompt “enter into shortcutmode”; otherwise, you need to close the shortcut and press “# key” to close it.The prompt is “restore to shortcut mode”.
    2.Enter the remote control shortcut interface andclick the iconAs shown below
    3.click Shortcut, enter theremote control shortcut settings interface
    4.Description of the functionsof each button of the remote control shortcut
    "Number 1 key"------------------------- Screenshot
    "Number 2 key"------------------------- Enter the background to clear all / single application
    "Number 3 key"------------------------- Press the top navigation bar twice (retract and pressthe return key twice)
    "Digital 6/7/8/9keys" ------------------ You can choose to add any application
    Mouse operationscreenshot (for model version: GT1, A1, GS1, MINI XIII II all system versions)
    Another way to take ascreenshot: If the remote control is not available, use the mouse to slide outthe bottom navigation bar below, there is a small camera-like icon, you canclick on the screenshot. As shown below
    For more details, visit the link: http://www.bee-link.com/forum.php/fo...read&tid=41747
    You may only view thumbnails in this gallery. This gallery has 5 photos.
    Last edited by Beelink; 04 September 2018, 10:46. Reason: Beelink, tv box , GT1 , A1, MINI XIII II ,screen capture function
