HELP
I've had that problem w/the pmid4311 before. only solution I found was to reflash the ROM
EDIT: And of course, right as I say the above, I find a better answer. try using ES file explorer or root explorer and delete the /data/misc/wifi/wpa_supplicant.conf file and then reboot. let me know if that works.
There are currently 3805 users online. 1 members and 3804 guests.
