RK3328 2GB RAM + 16GB ROM 2.4GHz WiFi Bluetooth 4.0 1000Mbps LAN
Specification
Model: T98 Type: TV Box GPU: Mali-450MP2 System: Android 7.1 CPU: RK3328 Core: 1.5GHz,Cortex A53,Quad Core RAM: 2G RAM Type: DDR3 ROM: 16G Max. Extended Capacity: TF card up to 64GB (not included) |
Decoder Format: H.265 Video format: 4K Audio format: AAC,FLAC,MP3,OGG,RM,WMA Photo Format: BMP,JPEG Support 5.1 Surround Sound Output: No |
5G WiFi: No WIFI: 802.11b/g/n Bluetooth: Bluetooth4.0 Power Supply: Charge Adapter Interface: AV,DC Power Port,HDMI,RJ45,TF card,USB2.0,USB3.0 Antenna: Yes Camera: Without Language: English DVD Support: No HDMI Version: 2.0 Other Functions: 3D Games,3D Video,Airplay,DLNA,Miracast,PAL HDMI Function: HDCP Power Consumption.: 8W RJ45 Port Speed: 1000Mbps |
System Bit: 64Bit |
Power Type: External Power Adapter Mode |
Remote Controller Battery: 2 x AAA Battery ( not included ) |
Product weight: 0.1500 kg Package weight: 0.3700 kg Product size (L x W x H): 11.00 x 11.00 x 1.90 cm / 4.33 x 4.33 x 0.75 inches Package size (L x W x H): 18.30 x 11.00 x 7.50 cm / 7.2 x 4.33 x 2.95 inches |
Package Contents: 1 x TV Box, 1 x Power Adapter, 1 x HDMI Cable, 1 x Remote Control, 1 x English Manual |
Gearbest
