Product link: https://bit.ly/2PM12y7
The Intel Core i7-8709G is a fast quad-core processor based on the Kaby Lake architecture. Similar to the Core i7-7920HQ, it integrates four processor cores clocked at 3.1 - 4.1 GHz. As a speciality, the package also contains a Vega based graphics card from AMD (with 24 CUs = 1536 shaders at 1190 MHz) and 4 GB HBM2 graphics memory. Compared to the i7-7920HQ, the i7-8709G should be slightly faster due to the HBM2 memory and the 100 Watt TDP. The performance is therefore sufficient even for very demanding tasks and on par with powerful desktop quad-core processors. In addition to the Intel HD Graphics 630 in the CPU die, the Core i7-8709G also offers an AMD Radeon RX Vega M GH graphics card with 24 Cus and therefore more than double the amount of the current Ryzen APUs (e.g. Ryzen 7 2700 with 10 CUs). Contrary to Skylake, Kaby Lake now supports hardware decoding for H.265/HEVC Main 10 with a 10-bit color depth as well as Google's VP9 codec.
CPU: Intel Kaby Lake G i7-8709G , Quad-Core
Equipped with better performance, delivering plenty of power for multitasking and fueling casual games and movies.
DDR4 16GB RAM, 256GB NVME SSD
It boasts DDR4 16GB RAM, 256GB NVME SSD, advantageous in performance, security and reliability.
2.4G/5G Dual Band WIFI,802.11 b/g/n/ac
Supports 802.11 b/g/n wireless standard, among which 802.11b has a maximum bandwidth of 11 Mbps, 802.11g 54 Mbps and 802.11n 150 Mbps.
Gigabit LAN
Gigabit LAN provides a data rate of 1 billion bits per second.
HDMI 2.0 Connector
You can go directly to let your TV and MX10 TV Box are connected through an HDMI cable and set up your home cinema for the best 4K x 2K UHD multimedia experience.
Check more info: https://bit.ly/2PM12y7
