HELP T95X ISSUES IN FLASHING AND RECOVERY IN NEED OF SHORT PINS
    Hello Everyone, have a T95X with s905x 1gb/8gb i flashed it with ATVXPERIENCE TEST ROM it was for mxq pro 4x s905x 1gb/8gb.
    i thought both has same processor and same ram so it would be compatible. the rom booted i'm able to use the box but i'm not ableto go into recovery mode nor flash mode.
    i want to flash another rom usually i connect to pc , press the button inside av port and power it up and it shows up in burning tool but now after this rom flash its not detecting.
    tried burn card maker, it boots directly to home screen.
    remotely connected adb and gave reboot recovery boots straight to home screen again.
    finally decided to short pins but i having difficulty in find the right spot, tried shorting pins near NAND arrow, it reboots back to home screen no detection in PC.
    any help would be appreciated, Thank You. have attached the pics of motherboard. Click image for larger version
    Nevermind found out the short pins thanks to scooter2014 in the post
    ill add it up here incase it may help someone. Thank you.
