Stock Android 7.1.2 base, post 02/2018 firmware, with a minor patch to force Google into updating TV services, and function with optional Leanback options.
Requirements, developer Webview 52.xxxx baked in and active.
Options, Leanback Launcher install package and Chrome is not required.
Bonus, add Live Channels without Leanback Launcher, and use custom Launcheres with functioning background wallpapers. Nova Launcher should function just fine, if installed and working before OTA krack patch. ATV and Phone apps supported. Fixes volume control and mute function seen on custom ARM8a 64 ATV firmwares.
Issues, Youtube 2.03.xxx and latest YouTube TV release are broken. SBS On Demand broken. Play Store is ATV only. Daydream broken on some stock firmwares, so don't expect this patch to fix. To test, please use the Magisk module Daydream Enabler. If it don't work, it's because of the firmware build.
Basically you will have a crossbreed firmware to make the best compatibility.
I dont have the ability to create a OTA package right now, but I am working on it.
