Hello everyone I own this tv box android. I wondered where I can find a list with the ROMs to update and the firmware update procedure. thank you.
B qeel X9T Box Android Android 6.0 / Amlogic S912 64bits/ 4K Ultra HD / 2GDDR3+16G EMMc
Originally posted by trebor View Post
saluti.You may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
This One May work
http://freaktab.com/forum/tv-player-...r-beta-testing
2 versions
The number on the WIFI chip under side PCB silver one should determine what version of firmware to try
Ram is also different than the Tanix, may or may not be compatible
Plenty of Info on freaktab on how to Burn if unsure
Or you can try to get intouch with supplier/seller of your BOX
Also it looks like it might be the X9T found it on Gearbest, not seen in the wild yet on Freaktab
There are currently 3663 users online. 5 members and 3658 guests.
