#Flashsale Smart Plug WiFi Outlets Mini Smart Socket Remote Control ( 3Pcs ) , $23.99, Shipped @GearVita
    Enjoy $23.99 and free shipping by using coupon code SmartPlug3, valid til Sep 15th
    Features:
    ● Work with Amazon Alexa, Google Home, Google Assistant, you can control your smart plug with your voice
    ● Connects to the internet through WiFi and controls the power of mini smart socket with "Smart Life" APP ( downloaded from Google Play or Apple Store ) in the smartphone
    ● Use mobile phone or tablet remote control and check home appliances power supply anytime from anywhere
    ● Allows you to save electricity and money without wasteful power supply
    ● Set timing control mode and schedule the smart adapter to automatically power electronics on and off
    ● Easy to use and set up, no hub required, just plug in and set up according to the instruction
    Buy Here: https://gearvita.com/smart-plug-wifi...trol-3pcs.html
