Well this time im doing something that i rarely do that is writing a review... well is more of a mini review because i suck at reviews lol
Anyway im here to write about something i bet lots you use and that is a VPN service with the name of SpiderVPN.
What is different from this one to the rest i used before, well you get a free router
Im using for a few months now, and i have seen the service going up and up and up in the available vpn locations and speed, you also get 2 of them dedicated to Netflix (One US and one UK).
Now.. lets start with the router, you have 2 versions a PRO and a NON PRO, the one i have is the PRO so im talking about that one.
The router build quality is great, you get 4 5DBI High Gain Antennas with it, all ports is gigabyte, the cpu used is a MediaTek MT7621, and it have 512mb of ram, 2.4g and 5g wifi bands.
The fw is a custom version of openwrt(at time of this writing the fw version is 120918) so you have lots of options there and i mean a lot...
Now, you can use as a vpn router for all of your network, or as normal router... all you need is to disable the "WGSPIDER" in Network/interfaces.
Well not much else to talk, unless the speeds are great, i have a 1Gbit/200mbits connection and i get using the US vpn 220mbits/140mbits, all the other locations are +/- the same for me.
So for downloads and uploads is great speed, best one i used so far.
You have several plans so theirs plans for all wallets, im using now the PRO 12months, and 24h support.
Well i dont have much more to tell other that i TOTALLY RECOMMEND IT.
More info:
Site: https://spidervpn.org/#a_aid=5b9ee765e5347
Twitter: https://twitter.com/adminspidervpn
Facebook: https://www.facebook.com/Spider-VPN-184809502074424
I will leave now you guys with some pictures for the router and fw of the same.
Not all of the FW but the main things...
