box a95pro brick and red led
hello, I have a box a95x pro and it is brick red led after a flash with a bad rom via usb burning tool now my box is no longer detected by usb burning tool and red led like nt do to save my box thank youYou may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosTags: None
Your only hope is to get into the Recovery Menu while connected to your TV using the tooth pick to depress the "reset" button, which is in the AV hole. If you can get into the Recovery menu, then you have a chance.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostYour only hope is to get into the Recovery Menu while connected to your TV using the tooth pick to depress the "reset" button, which is in the AV hole. If you can get into the Recovery menu, then you have a chance.
There are currently 1481 users online. 2 members and 1479 guests.
