Product link: https://bit.ly/2ML5kUf
$279.99 after coupon: GEMININ50
Intel Gemini Lake N5000, Quad Core
The Intel Pentium Silver N5000 is a quad-core SoC running at 1.1-2.7 GHz (Single Core Burst, Multi-Core Burst max. 2.6 GHz) and is based on the Gemini Lake platform. Similar to the Apollo Lake predecessor, the chip is manufactured in a 14 nm process with FinFETs but offers slightly improved processor cores, double the amount of L2 cache, a smaller package, a new generation of monitor outputs (Gen 10) and a partly integrated WiFi chip. Besides four CPU cores, the chip also includes a DirectX 12 capable GPU as well as a DDR4/LPDDR4 memory controller (dual-channel, up to 2400 MHz). The SoC is not replaceable as it is directly soldered to the mainboard.
Pre-installed Windows 10
Beelink Gemini N50 Mini PC is pre-installed Windows 10 home so that our users are able to enjoy the advanced functions of Windows OS directly. Moreover, the built-in Cortana in Windows 10 can turn Beelink Gemini N50 into a work assistant as well as life-partner. With Windows 10 OS, you can sync game display to any devices of Windows 10 OS. What an amazing scenario! When your friends are watching football matches on TV, you can play games on Xbox and display on another PC screen.
LPDDR4 8GB + 128GB SSD
Configure 8GB memory and 128GB of SSD storage space, with smooth and responsive navigation and apps that launch quickly.
Dual Band WIFI
With support for 2.4Ghz and 5.8Ghz band, it can transmit higher amounts of data, and its naturally less congested.
1000M LAN
1000M LAN can improve the net speed and the performance to a large extent.
Check more info: https://bit.ly/2ML5kUf
