Libreelec for rk3328
For those of you who want remote control on MX10 I made a custom rc_keymap . Add this to your libreelec distribuition with winscp ( ctr-alt-h for view hidden folders ) and reboot.More info and step by step tutorial at https://wiki.libreelec.tv/infrared_remotes.Attached Files
Originally posted by ukmark62 View Post
Yeah - weird. All I did was upgrade using following image https://androidtvbox.eu/new-firmware...-soc-20190108/
Used android tool v2.59 to erase flash and then upgrade and did nothing else. All these entries appeared once I upgraded to Android 9.0
Originally posted by antonio6o6 View PostI put this file on my R10 TV BOX and now I have Internet connection and PVR Addons is working on my stocker LibreELEC-RK3328.aarch64-9.1-devel-20190124145800-2f2cce8-box-trn9.img Thank you for you help and for pointed me the file. mo 123.
Originally posted by polo_joe View Post
Thanks for your latest builds, I tried 5.x test build but has no ethernet so not very useful yet.
In 4.4 kernel as phy-supply = <&vcc_phy>;
https://github.com/150balbes/LibreEL...ts.patch#L4733
In mainline as phy-supply = <&vcc_io>
https://github.com/Kwiboo/LibreELEC....lec.patch#L732
Mainline has missing &gmac2phy & vcc_phy, present in 4.4 kernel.
Maybe something about that cause ethernet to not work?
You perhaps know why LibreELEC forum removed Github 3rd party login?
I can't login now to their forum.
balbes150
New test version 20190630.
Please note that the new versions are built using the main (under development) branch of LE and may contain some non-working functions. Importantly. New images have dtb (box) file by default. To work correctly, you need to change it to the desired version. All dtb files are now placed in the /dtb/rockchip directory.
There are currently 2180 users online. 1 members and 2179 guests.
