Help on T95z plus
    Help on T95z plus
    I recently bought 2 T95z plus devices from a local seller within a few weeks from each other.
    I am quite confused as they don't seem to behave exactly the same.
    One thing that annoys me is that when I press the power button on one, it shows a pop-up that says 'Power off' or 'Restart' while the other one goes to sleep. I checked in the Droid Settings under powerkey definition, and both of them are set to 'Sleep'. How can I get the first one to simply go to sleep without showing this pop-up? Can't find any settings that help.
    Edit: Did some more testing and it looks like my box #1 interprets even a short press of the power button as a long press. Anyone knows if there is a way to change that behaviour?
