New firmware v2.1.12 beta version for ZIDOO X9S released
    As Found
    Update list:
    System
    1.Fixed problems with green bars at the bottom of some specially coded MKV video playback
    2. Increased the optical drive function
    - Support CD/DVD/BD SATA and USB optical drive
    - -Add an optical drive device to the file manager left device list when there is optical drive access. The content area can display multiple optical drives and support volume label, and the menu key can be used to operate the current optical drive
    - Support for un-encrypted DVD/BD playback, support for Blu-ray and DVD navigation, and any file supported by player stored in the optical disk
    Shortcut settings
    1. Play Settings - function keys - up and down keys - add the option of adjusting subtitle position
    2. Optimize resolution display
    3. Play Settings - function key - subtitle audio key - default select list mode
    File manager
    1. Fixed problems caused by unresponsiveness of applications due to emergent access to NFS
    2. Added the function of video play record. The viewed video will be displayed on the right
    3. Added the optical drive list function
    4. Added AIF music support
    Local player
    1. New UI display
    2. Increased multiple ratios(4:3,16:9, original size,solved some DVDs improper ratio )
    3. Optimized video information display
    4. Added the function of setting up the upper and lower keys to adjust the subtitle position (change the setting in the shortcut setting)
    5. Added startup to display video name
    6. Added up key to the pause interface to cancel information display (information can be displayed when the player's advanced Settings are closed)
    7. The subtitle audio list interface selects the current item by default
    8. Fixed the subtitle problem in the subtitle download interface
    9. Optimized the subtitle download interface display
    10. Added random playback mode
    11. Added and delete single video subtitle function
    12. Record the proportion of single video play
    13. Add DVD resume playback function
    14. Optimize the saving mechanism of single video subtitle
    15. Added output parameter display in the information interface
    16. The progress bar increases the remaining time display
    17.Optimize the automatic switching function of 1080i resolution
    Wall Poster
    1. Fixed the problem that video with demo cannot enter the poster wall through file manager
    2. Fixed the problem of rematch interface to add episodes without input number error
    Blu-ray navigation
    1. Added resume playback function (synchronize playing record with local player)
    2. Optimize the saving mechanism of single video subtitle
    3. Fixed the problem that the idol progress bar does not show
    4. Fixed the problem that part of video cannot display external subtitles
    5. Fixed part of the navigation failure problem
    Openwrt
    1. Added NFS SERVER function
    2. Added SMB, NFS SERVER permission management
    3. Optimization interface, now there is a simple configuration interface
    4. Optimized Transmission,Aria2 startup script, no need to add SLEEP parameters now
    5. There will be repeated problems in optimizing device mount
    Model:ZIDOO_X9S
    Version:v2.1.12
    Download url:http://apidl.zidoo.tv/X9S/v2.1.12/ZI...261546-ota.zip
    MD5:D4EFAA581A0435EBE95274C26CF7FE44
    Update style:0TA
    How to upgrade
    We also released a alpha version for music 3.0, For install music 3.0 the firmare version above 2.1.12 is necessary
    Music player 3.0
    1. Modified the original layout of music player 3.0, separate the music list and play interface, and put the play panel at the bottom to restore the user's customary operation mode.
    The control is optimized according to the box characteristics
    2. New categories are added by artist and by album. Now the playlist is divided into 6 categories: collection, all songs, artist, album, song list and folder.
    3. New song categories by genre can be viewed in all songs
    4. New artist categories by region can be found in the list of artists
    5. Added a new song list system, and users can classify and store the songs according to their favorite ways
    6. Play details is now a separate interface where song information, file information and lyrics are displayed
    7. New sorting function
    8. New view switch function, grid view and list view, artist classification and unique poster wall view
    9. New search function, and support song, artist, album classification search, and can edit every element found
    10. Optimized the effect of the lyrics, and the lyrics display is accurately positioned to word by word, so that the lyrics display is more accurate
    11. Support for new transliteration lyrics and translation lyrics
    Optimize lyrics search, now mainstream songs can be searched basically
    13. New manual lyrics search function is added, and the lyrics effect of search results can be previewed, so that users can choose the most suitable lyrics according to the effect
    14. Now the folders added by the user will be uniformly placed in the folder category of the music list for easy editing of the folders
    15. Optimized the original scanning mode. Now the song scanning will be carried out in the background and the songs will be updated dynamically
    16. You can see the progress of the scan in the folder list in the scan and stop the scan at any time
    17. Now, when scanned the CD image file music or the FLAC,APE and WAV files with CUE, the single is directly parsed and the single is matched for song, the image file is matched for album, and then classified into different lists
    18. The resolved singles will be put in all the songs like regular music, and will also be put in the corresponding album according to the song information matched
    The CD's mirror image matches the album to be placed on the album list, and the album contains the complete singles that are parsed from the file
    The folders of mirrored songs will only show mirrored files as files, and the playback will play all the songs in the files from beginning to end.
    21. Added a play queue. When the user clicks the list song for playing, the playlist will be automatically added to the list where the song is.
    The play queue also provides all added songs and all favorites/unfavorites, as well as the ability to edit or move a single song from the list
    22. The control of the mobile phone follows the original layout and operation mode, which is consistent with the function and previous version
    23. Supports APE/FLAC/WAV/AIF/DTSCD/MP3 / SACD ISO/DFF/DSF file playback, support for the DSD file decoding the highest sampling rate of 192 Khz, DSF file decoding the highest sampling rate 176.4 Khz
    Source: Zidoo
