For some strange reason I can’t update the box to 7.1.2 anymore but it runs fine in 6.0.1... it stucks in h96 mx logo after update...basically The box was running 7.1.2 02/05/18 versions just fine and then I decided to update it to latest version which is 13/7/18....then stuck in logo,tried reset option many times but same result....it won’t mount aswell in reset option area..now it only runs in android 6.0.1....any idea or suggestions??
H96 max 4gb 32gb,rk3399 , can’t update to android 7.1.2
H96 MAX 4gb 32gb
For some strange reason I can’t update the box to 7.1.2 anymore but it runs fine in 6.0.1... it stucks in h96 mx logo after update...basically The box was running 7.1.2 02/05/18 versions just fine and then I decided to update it to latest version which is 13/7/18....then stuck in logo,tried reset option many times but same result....it won’t mount aswell in reset option area..now it only runs in android 6.0.1....any idea or suggestions??Tags: None
There are currently 1533 users online. 1 members and 1532 guests.
