[ROM] [S912] atvXperience v2F
Originally posted by thewebexpert View Post
do you don't know if they are banned, you just think they might be banned and you are spreading FAKE NEWS. sad.
neomode
i understand
i don't know much about this but its a waste that atvxp is not here. they are good guys and have helped me multiple times i am sure they have helped others on here too. they told me it was a misunderstanding so maybe you should try to talk to them
i don't have anything in this matter though nor do i want to know what happened between you guys but i believe there rom deserves to atleast be here and it doesnt hurt when you have more people helping out on the forum so you should talk to them
i love your work in poison too
Guest
Loaded it on my Sunvell T95U Pro (S912 V2F). Everything seems great right now. Could not get it to load using SDBurn maker, but USB Burning tool worked fine.
Wifi and Bluetooth both work. Front panel clock does not work which I really don't care about. May try out the clock patch for the other unit and see if that works.
Way smoother then stock 6.01 or 7.1 Roms. Dock is way nicer.
Originally posted by edsoedso View PostHello!
Thank you for your work! Is it possible to install this rom on H96 Pro+ TVBox S912 3Gb ram, 64 Gb rom? My stock rom is NHG47L.20171031.
Website is currently down, so will have to wait for download links.
There are currently 1367 users online. 1 members and 1366 guests.
