(Might test soon
.gif)
Dev: Kam_58
https://4pda.ru/forum/index.php?show...#entry74682496
Android 6.0.1
Negative:
Remote may not work and no WiFi
Positives:
Better control of permissions.
Media not borked like Android 7
Auto Frame-rate works
Use USB Burn Tool to flash the image
Flash Boot Loader must be selected...if needed to return to Android 6 from Android 7
** Remote Config (needed?)
** TWRP (If not installed)
The TWRP is launched from the SD card. To do this, download the recovery from the link and copy it to an SD card formatted in FAT32.
Turn off the box completely, disconnect the power cable. Install the card in the slot. With thin wire or toothpick in reset hole, press and hold and plug in power.
Continue to hold the reset until TWRP appears...(or only press and hold for several seconds then release..)
** For Root (Untested and unverified)
"Download the installer,(place in Downloads folder?), launch TWRP and install SuperSu and reboot.
After the screen/box(?) reboots twice. Root is installed."
https://drive.google.com/file/d/0B_4...TJRRHpmTkRERkE
