on the thread http://freaktab.com/forum/tv-player-...-max-h2-rk3328
H96Max remotely blocked?
Originally posted by Joust View Posti got that short here picture from a post by http://freaktab.com/member/10154-manu_manu4
if possible try it with a fresh installed Win7 or 10 what you have , it looks like the pins are correct ,
but there is another Picture in Post5 , did you tried that too , looks like it worked for the User ?!?!
Did you already contacted the Seller about that ???
greetings / gefatternLast edited by gefattern; 16 October 2018, 00:40.
that post #5 shows pins on the USB hub controller chip. https://www.kean.com.au/oshw/WR703N/...Hub%201.07.pdf thats the DVDD which is 3.3v pin and the last one is ground. That certainly will not work as you are turning off that chip if not destroying it. he said he had success using the pins in the picture i posted.
The seller is not an options because as i said in the first post, he is extremely uncooperative and claims to have remote destroyed my box. i'm beginning to believe he may have done so.
Private message me if you want to know who i bought it from. . i debated posting details ,I think people should be warned. I can if its ok but don't want to break any rules.
Originally posted by Joust View Postthat post #5 shows pins on the USB hub controller chip. https://www.kean.com.au/oshw/WR703N/...Hub%201.07.pdf thats the DVDD which is 3.3v pin and the last one is ground. That certainly will not work as you are turning off that chip if not destroying it. he said he had success using the pins in the picture i posted.
for sure they must be warned , you can inform Aliexpress self , that this happend , if you buy
a TVBox u always get a Powersupply with it , that is already strange , i can ask the others ,
maybe we can make a sticky Post with "Bad Sellers" , good luck / gefattern
Originally posted by Joust View Postno its still not working.
but...
good news is that i got a refund from the dispute i had on the seller at Aliexpress.
its likely gone bad. the thing will not do anything at all. just the blue light comes on.
The system reports "Unknown USB Device"
small hint after Driver install , the PC must be rebooted , for working correct ,
1. install Drivers (always latest)
2. start Flashtool (as Admin) , load Firmware ,
3. press "reset" Button , (often behind AVJack)(hold it)
4. connect with USBCable to PC , (use the right USB port of Box)(for PC no Hubs / direct Ports)
5. connect Powersupply , (wait till connected , then leave the "reset" Button)
6. restore your Box
for short Pins Way , ( MaskRomMode )
1 & 2
3. short Pins ,
4. connect USB
5. connect Power
device will show up in MaskRomMode ,
6. restore your Box ,
Originally posted by Joust View Poststill not recognized.
last resort will be to try another PC maybe on Win8.
i did try a second on win7.
same...dead box
hope you get it , greetings / gefattern
looks like there is a new Rom in the "H96 Max+ 4/32 or ..... Android 8" Thread started by Trebor
I found when I attempted to flash the box does not detect as I expected
As in plug in detect hit the burn button, done
Runt the burning tool load the .img then hit Burn
Then short the pins then plugged in
http://geekbuying.mediafire.com/file...Video.mp4/file
There are currently 2723 users online. 1 members and 2722 guests.
