X96 MAX TV Box BLACK 4/64GB Amlogic S905X2, Android 8.1, Dual WiFi, Gig Lan,USB3.0, BT4.0
Hi ppl. Is there any full review with antutu benchmark of Amlogic S905X2 CPU? What is this processor compared to S905W, S905X and S912 (and Dvalin MP2 GPU compared with Mali-450MP2 and Mali-T820MP3)? I see that the most boxes with S905X2 comes with 4GB of DDR3 RAM. Is that amount of RAM overkill for S905X2? I hope so that is not one more cheat like in case with boxes that comes with 4GB of RAM and RK3328 CPU. 4GB is just cosmetic in this case. Thanks!
Originally posted by kolinsb View PostHi ppl. Is there any full review with antutu benchmark of Amlogic S905X2 CPU? What is this processor compared to S905W, S905X and S912 (and Dvalin MP2 GPU compared with Mali-450MP2 and Mali-T820MP3)? I see that the most boxes with S905X2 comes with 4GB of DDR3 RAM. Is that amount of RAM overkill for S905X2? I hope so that is not one more cheat like in case with boxes that comes with 4GB of RAM and RK3328 CPU. 4GB is just cosmetic in this case. Thanks!
Last S912 box i tested was TX8 (metal case with external antena like Mecool BB2) with Android 6.0, and it has 58336 points (antutu benchmark v7.1.0)
3D=12569 points
UX=14252 points
CPU=26775 points
RAM=4650 points
Last S905X I tested was X96 with Android 6.0 and it has 28009 points
3D=0 (I think that's because OpenGL 2.0)
UX=11296
CPU=11995
RAM=4718
Originally posted by kolinsb View PostPls install antutu and run a test (install antutu 3d too). Tnx in advance
Sent from my POCOPHONE F1 using Tapatalk
EDIT: Problem solved in a very old way. sdcard with Uboot. I'll send some raccomandation to the manufacturer, i'll fix their base fw. my custom is almost ready, i'll post it when the device will arrive in the buyers hands. Anyway it's good enough and best than S912.
Anyway if more 8.1 S905X2 or Y2 fw are out for other manufacturer let me know.Last edited by Xannytech; 19 November 2018, 18:40.
X96Max + 4GB +32G/64G+ 1000M Ethernet Latest firmware:
11-18-2018, 19:20
Update KD Player, update Kodi plug-in package.
8.1 increase Root management and open app Root.
Solve some App display problems after entering the interface.
Update web browser, play video display problem。
Sdcard firmware web Link:https://drive.google.com/file/d/1ULW...ew?usp=sharing
Originally posted by panchovilla View PostReceived the mecool KM9 today. Netflix is not installed . You have to install it. Will play with it some more tonight .
Originally posted by jiangsai0703 View PostX96Max + 4GB +32G/64G+ 1000M Ethernet Latest firmware:
11-18-2018, 19:20
I am using X96 Max for few days, overall it is good, but I don't see notification and navigation bars... Don't see any settings to enable them... Can you please check, and suggest, some way, to bring notification and navigation bars...? Notification bar is more important for me..
I downloaded the sd-card firmware, what is the source of this firmware..? is this official..? I am having X96 Max X2 (4 GB/32 GB).. Please share steps to flash this firmware..
Thanks..
11-18-2018, 19:20
Overall:60405
CPU:28001
GPU:9311
UX:18261
MEM:4832
Geekbench
SingleCore:729
MultiCore:2255
Compute:1526
Androbench
Seq.Read :~150MB/S
Seq Write :~110MB/S
Results may vary by manufacturer, but its look really fast especially when installing apps.Four core works 1.91ghz , its look like overall 50% faster than s912 boards(but s912 results from antutu 6),but not much difference in gpu.In benchmark rankings, roughly performance between Lg g3 and Samsung Galaxy S5.
S912 offers Arm's LITTLEbig for power efficiency but these box is not working with battery, users need more cores and frequency.Everyone excited s922x came four coretex-a73 cores with mali g52 mp4, but it will be expensive than rk3399 box.
Lastly there is a button inside av port, it is usable for using libreelec booting with tootpick method.
Comparison links
But a lot of glitches on android, its look like ota/fota supported , i'm waiting update.Last edited by deathline; 09 December 2018, 14:56.
There are currently 1964 users online. 0 members and 1964 guests.
