TikiGoGo Air Mouse Voice 2.4G
    Petrev X Has just done a review on this air mouse with Voice function. Unlike the previous versions of this type of remote, this one actually has a real air mouse. I just ordered one from his link, for a total of $10.18 USD........
    Thanks for posting
    Here's a few pix ...
    Mii vs MeCool vs TikiGoGo
    User Manual
      I finally received this remote today. The mouse function works great. The voice function is just about useless. It does make a good all around remote for **touch** apps like the Chrome browser, and it works very well for that. I tried using the method you posted on your YouTube channel, where you have to click the **assistant** twice, but that did not help.
        Click the assistant once - says listening, then hold the Mic button and talk, if it doesn't show any activity then release and hold again and normally works. Once you have done one voice search you have to use the back key, then press the assistant again ...
        I used it in YouTube today as well and it worked fine ...
          Thanks for the information, will give it a try.
