MK808B problem!! please help
    Hello
    I bought mk808b and i play movie with mx player pro and after 2 hours of viewing its exit from the player and i need to play the movie again and start it from the same point and its not exit from the movie again i play the movie from a sandisk 8gb flash drive.
    i play another movie that shorter than the first movie and its exit from the movie several times in different points in the movie. i play this movie from a powered external hard drive 1tb seagate.
    the problem not from the movie i have tested it in my computer and its play normally.
    why in the second movie its exit more times than the first movie?
    the movies works without stucks but the only problem is exit from the movies.
    and its happend in others players like bsplayer, mvideo player and etc.
    what i need to do?
    please help!
    Originally posted by asaf27067 View Post
    Hello
    what i need to do?
    please help!
    Do you use a 2A power supply?
    Use a custom rom as it's faster and more stable.
    The default RKVideoPlayer plays video much better.
    Also make sure you have a good wifi signal.
      yes here is my power supply
      what custom rom do i need?
      i have a good wifi signal but i dont play movie from wifi i play from hard disk or usb
        You can try http://www.freaktab.com/showthread.p...822-05-2013%29
        In MXPlayer settings you can enable H/W+ support and when a video plays, change it from H/W to H/W+ for better video playback. Also install the neon codecs for MXPlayer.
          another suggestions?
