Severe problems with Play Store in a Wosung NC 95-X
    Hello! I'm new in the forum I just buyed today the Wosung TV BOX with this specs,
    Mini Android TV box: 3.74 x 3.74 x 0.55 inche
    Android OS: Android 6.0.1 OS
    CPU: Amlogic S905X Quad Core A53 2.0 GHz
    GPU: Penta-core Mali-450MP
    RAM: 1GB DDR3
    Memory size: 8GB EMMC Flash
    WIFI: 802.11 b/g/n
    Video: 3GFLV、MP、Mp4、MPG、MPEG、WMV、3G2、MKV、AV1、FLV、M2TS、MTS 、ASF
    Image Browser: Support JPEG、BMP、GIF、PNG
    Audio: Mp3、0GG、WAV、AAC、MID、WMA、APE、M4A、FLAC
    Remote Control: Support phone control, 2.4GHZ wireless mouse/Remote controller
    The thing is I have two problems, one of them MAJOR:
    MAJOR: Is impossible to install any app, just a few, everything just says that I can't install because my device is not compatible with the app (and I'm saying like Nova Launcher...). I updated Play Services, tried to update Play Store but just crash and stay in the same version. I deleted cache, data, turn off and turn on the devices and nothing happens...in an app to get notify if I can receive updates of play services just say that it isn't installed or it is incomplete. Please help!
    a possible solution is to go to xda forum and download "galaxy market" now named aurora
    after install... go to settings...
    quote:
    "You can also Spoof your Device Information, Language and Region to get access to the apps that are not yet available/restricted in/on your Country/Device"
    good luck..
      good luck..
      well, thanks mitchell, I was trying but I didn't see that option. I used Yalp, and simulate the device, just there I was able to install
        someone advice me to install a new rom, tell me that A95X rom is the adequate but says that I have to open the device
          well, it did work but in someway the ram doesn't help over the functionality of the device. Is there another way to make work the play store? I don't have the device rooted
