I tried to find the firmware online with no luck at all! The Build is (RK322x_box-userdebug 8.1.0 OPM5.171019.019 eng.user.20180825.171904 test-keys). I have a friend that has the same box, is it possible to somehow extract the image.
Help with Mini HK1 Firmware
I purchased a Mini HK1 RK3229 2GB-16GB TV Box Android 8.1 online that came with SuperUser app for root. The box was working fine, I tried to install SuperSU app, and it asked for reboot. Once I rebooted I got stuck at boot. I am hoping I can get the firmware to fix it, or if you recommend some other way to reset it.
I tried to find the firmware online with no luck at all! The Build is (RK322x_box-userdebug 8.1.0 OPM5.171019.019 eng.user.20180825.171904 test-keys). I have a friend that has the same box, is it possible to somehow extract the image.Tags: None
Originally posted by Beho86 View PostI purchased a Mini HK1 RK3229 2GB-16GB TV Box Android 8.1 online that came with SuperUser app for root. The box was working fine, I tried to install SuperSU app, and it asked for reboot. Once I rebooted I got stuck at boot. I am hoping I can get the firmware to fix it, or if you recommend some other way to reset it.
sounds not nice , but your Friend can make a Backup of the Image with
AndroidTool2.35 or higher , then you can flash back your Rom ,
but it must for sure the same Box , same Specs & Chips ,
good luck / gefattern
My situation was different as it was not booting at all. If you have recovery running, what happens if you just wipe/reset the box? I did end up doing a image dumb and flashed every partition by itself in (AndroidTool 2.38).
The issue is the image I got from my friend had all his accounts and some apps that he moved to system, so I won't be able to share the files publicly. I am not sure if it will help if I share these files or not (Parameters, uboot, baseparameter, oem, misc, vendor, RK3188Loader.bin, boot). let me know if that would work. I will look into getting a cleaned system image as well.
Originally posted by Beho86 View PostMy situation was different as it was not booting at all. If you have recovery running, what happens if you just wipe/reset the box? I did end up doing a image dumb and flashed every partition by itself in (AndroidTool 2.38).
Originally posted by Beho86 View PostOk, I will do you a favor! I will backup my box first, and and reset it, redumb a clean image, and send it here. I will try to do it today.
Keep in mind you will need male-male usb cable, and androidtool 2.38 to flash those partitions.
There are currently 1305 users online. 0 members and 1305 guests.
