MK888B / T-R42 which is basically MK888 with bluetooth from here AliExpress at 84$ or
Radxa Rock which is build by Tom Cubie, the creator of CubieBoard, with similar specs from MK888B:
SoC – Rockchip RK3188 ARM Cortex-A9 quad core @ 1.6Ghz + Mali-400 MP4 GPU
System Memory – 2GB DDR3 @ 800Mhz
Storage – 8GB Nand Flash + micro-SD SDXC up to 128GB
Video Output – HDMI 1.4 up to 1080p@60hz, and AV output
Connectivity:
- 10/100M Ethernet port
- WIFI 150Mbps 802.11b/g/n with antenna
- Bluetooth – Bluetooth 4.0
Audio I/O – Audio S/PDIF, headphone jack
USB – 2x USB 2.0 host port, micro USB OTG
Debugging – Serial Console
Misc – IR sensor, power key, recovery key, reset key, 3 LEDs, RTC
Expansions Header -80-pins including GPIO, I2C, SPI, Line in, USB 2.0, PWM, ADC, LCD, GPS… etc
Without the remote control and with a much simple case at 89$.
Both devices are new on the market and don't have a great user base, but their predecessors have (MK888 and CubieBoard)
So, my 89$ question is: which should I buy from this two devices Radxa or MK888?!?
