T95Z Plus flash ROM without reset button help
Trying to flash custom ROM to my Sunvell T95Z Plus but it doesn't have any reset button so I can't enter recovery mode. Tried with this method https://www.youtube.com/watch?v=POJRPMymBHo but I got Erase bootloader/Lowper/Identify/Error result. I guess it's a KLMBG4GEAC-B031.You may only view thumbnails in this gallery. This gallery has 3 photos.3 PhotosTags: None
There are 4-hole pads on the board,
between SD-Cardreader and USB-Port. Soldering is not essential. A contact (mechanical) is sufficient.
The 4-hole connection order is almost always the same on each PCB, starting from GND (the only square-hole)
PIN-OUT:
1. GND
2. TX
3. RX
4. 3.3V, VCC (is not needed)
Connect the pads to the PCB with appropriate Serial-to-USB-Converter ports and connect the USB-Port of the Serial-Converter to the USB-Port of the PC with a USB-Cable.
GND (PCB) —<-----> GND (Serial-Converter)
TX (PCB) <-----> RX (Serial-Converter) <-----> USB-Port (Serial-Converter) <-----> USB-Port (PC)
RX (PCB) <-----> TX (Serial-Converter)Last edited by bumerc; 21 October 2018, 08:41.
There are currently 3884 users online. 0 members and 3884 guests.
