Anyway heres the pcb and bad component are marked with red. the upper right is likely M22 written on it, but the lower left something...D6X (please correct me if im wrong) and maybe there's other burnt material i did not see, and the fluid leaked already cleaned with some of it left
From above theres 1 slight burnt too marked with blue
lastly where can i buy the component and aside of solder, pinset, flux, and desoldering copper braid any specific equipments i need?
Many thanks
