Modded version of superceleron's Minix U9-H SCV1.
Untested..Tweak it till you break it.
(Not sure if WIFI works in this mod?)
Modded:Maikl000000
[supercelerons main effort:
Changelog V1:
- Ok i could do a nice changelog bla bla bla... but i really don't have the time and mood to do it...
- Is as close to a "true" android tv rom as possible and some bugs fixed....
- Netflix Android TV flavor is not working as i think you know why... theirs other options but none involve the android tv version... google it.. or search the forum..
- NO TWRP.... like i said above is a close as original ATV you get...]
Maikl000000 Mod 10-21-18
The remote turns on and off the box, the mouse button on the remote does not work.
Installed four launcher, two of them ATV.
Integrated TWRP.
Integrated SuperSu (root).
Integrated init.d for user scripts.
Added library Open GL 3.2 for the performance of games and graphics.
Integrated AFR of two types, from anpaza is enabled by default and the system can be enabled in the TV settings.
The status bar and the navigation bar is in Immersive Mode (always hidden and translucent), appears when you hold the mouse.
All Google services have been removed, third-party markets have been added.
All unnecessary ones can be deleted via the shortcut with the basket and reboot.
Works MTP (transfer files via usb over the wire for firmware) To work MTP in the settings for developers disable usb debugging
Download for LP
Download for Non LP
Interesting boot logo can be installed (with 4da.ru account)
https://4pda.ru/forum/index.php?show...oil-70443513-1
