EACHLINK H6 Mini TV Box Allwinner H6 3/32GB 2.4G WiFi Fast Lan USB3.0 BT4.1
    EACHLINK H6 Mini TV Box - Allwinner H6 3GB RAM + 32GB ROM 2.4G WiFi 100Mbps USB3.0 BT4.1
    The EACHLINK H6 offers 6K output which provides you ultra high definition viewing and fluent video playing, making it as the highest resolution signal available for home movies. It has 3GB RAM, and 32GB ROM storage space, enough for installing any of your desired apps. You won’t worry about video interruptions and picture distortion. You can simply plug it into your TV, and you are good to go!
    Main Features as found
    ● Supports HDR 6Kimage
    3GB RAM + 32GB ROMlarge memory and expandable storage
    Android 7operation system
    ● Allwinner H6 CPU, quad core, Cortex A53
    ● Mali T720 GPU
    ● 2.4GHz WiFi
    ● Supports H.265 decoding
    Gearbest
    Thanks to Gearbest today we can have a close look at the EACHLINK H6 Mini TV Box Allwinner H6 3/32GB 2.4G WiFi Gig Lan USB3.0 BT4.1
    Specification as Found:
    Brand: EACHLINK
    Model: H6 Mini
    Type: TV Box
    GPU: Mali-T720
    System: Android 7.1.2
    CPU: Allwinner H6
    Core: Quad Core
    RAM: 3GB
    RAM Type: DDR3
    ROM: 32G
    Max. Extended Capacity: 64G
    Decoder Format: H.264,H.265
    Video format: 4K,ASF,AVI,DAT,FLV,ISO,MKV,MOV,MPEG,MPG,TS,VOB,WMV
    Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,WAV,WMA
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: No
    Bluetooth: Bluetooth 4.1
    Power Supply: Charge Adapter
    Interface: AV,DC Power Port,HDMI,LAN,SPDIF,TF card,USB2.0,USB3.0
    Language: Multi-language
    DVD Support: No
    HDMI Version: 2.0
    Other Functions: Others
    HDMI Function: CEC,HDCP
    Power Consumption.: 6W
    RJ45 Port Speed: 100Mbps
    System Bit: 64Bit
    WiFi Chip: 8723
    Power Type: External Power Adapter Mode
    Remote Controller Battery: 2 x AAA Battery ( not included )
    Product weight: 0.1200 kg
    Package weight: 0.3800 kg
    Product size (L x W x H): 9.60 x 9.60 x 1.90 cm / 3.78 x 3.78 x 0.75 inches
    Package size (L x W x H): 17.50 x 14.50 x 6.50 cm / 6.89 x 5.71 x 2.56 inches
    Package Contents: 1 x TV Box, 1 x Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x English Manual
    Let's have a look at what we have to start with:
    The Box
    What's in the Box, Standard remote,
    Front Clock a fav with some.
    Rear, No option here to plug in 12 power pack by mistake
    Side USB, TF and Reset
    Topside PCB,
    Undersie PCB, WiFi antenna in lid
      To continue, as seen above all the bits, and specs to make it happen
      Has the Option for the IR extender, and mount holes for some sort of TV mount (x96 mini comes to mind)
      Clock on the Front looking Ok not too bright.
      The Eachlink H6 is running Android 7 and working ok, speed for test etc also not to bad.
      When First turned on all the Segments of the display light up until into Android then Time etc.
      We do not have root access, no Upper or Lower bars.
      Netflix 480p L3 widevine watchable on smaller TV, and even Prime TV fired up worked out ok.
      A cheap little unit at the current Gearbest Special till the 28th of this month
      Would do fine for that Second TV, kids room etc.
      Clean looking UI simple and neat
      Setup to Google account WiFi all good, and installed testers easy and fairly zippy.
      Remote working pretty good for what it is..No fancy features found as yet
      Media button calls up MX Player
      TV button calls up YouTube 1080p
      Web button calls up Chrome
      App button calls up internal file browser.
      On with the show and tell:
      UI installed apps
      System A7
      DRM L3
      Sd Card Test ok Speeds
      CPU-Z
      Ram and Storage Truth
      Geekbench CPU and Compute More Info > http://browser.geekbench.com/v4/cpu/10435499
      WiFi Speed
      Gearbest
        A couple of other tests:
        GFX Bench
        3d Mark
        Not the fastest on the Block
        Should have some use, for under 40bills
        Thanks to Gearbest
          hmm.. I paid.. way to much.. for my h6 pro.. it seems
          35 euro... amazing with 3gb ram and 32gb of space
          note:
          title of post says " GB LAN" then later 100 Mbps
          title of post says "android 7.1" later it says android 7
          user review says " no root" app pic says "root yes"
          Thoughts..
          My h6 pro throttles when running "CPU throttle" app ( goverf ) could you test this?
          can the mini USB port handle the power.. I'm wondering..
          ​​​​​​is the Os 32bit on a 64bit CPU ?
          does Google play work.. like can you find : sentio or minecraft (as h6 pro doesn't work properly )
          cheers
            Yep typo in title fixed thanks mitchell4you
            Rest as found from website, i guess may happen
            Only A7 so far again may, only tested so far with ES file no Root
            Finds Senito and Minecraft,
            Confirm CPU throttle app ?
            10 minutes
            32bit reported by Antutu rest would not run
            The H6 Pro is a looker, presented very well, some of the scores Higher than this but as always only a guide
            But not too bad of a Bang for Buck.
              trebor what do you think about thermal specification of this box? It seems that CPU is a little hot (and that means it will force lower CPU clock). As I can see CPU-Z shows ~63°C, but CPU Throttling Test showing ~89°C ( I guess that is max temp). Dimension of BOX are 9.60 x 9.60 x 1.90 cm, and that's small box, and there is not a lot of space for heat dissipation. What about support? Manufacturer is complete unknown as I can see.Is it support any firmware update app? Tnx! I made once mistake with T6 mini android box, which was one of the first Android 7.0 box, and it never solved problems with firmware, cpu heat etc. Tnx in advance!
                Thermal is a little warm as noted, the unit has plenty of vents, most Other Android boxes and heat can be a problem confined space etc
                Small fan Underneath to improve circulation, would help.
                Plenty of Ideas to be found on FT and Modding Boxes.
                Support at this stage is unknown, and not many if any Devs work on H6 Allwinner,
                Cheap enuff at present working ok time will tell,
                Have been advised it will be getting an update soon, to 7.1, so appears to be some support about
                Good for that spare TV and on special till end of week at gearbest
                  trebor can you confirm that this box has OTA update?
                  Sent from my Redmi 5 Plus using Tapatalk
                  • trebor
                    trebor commented
                    Editing a comment
                    At this stage I can't, just advised it will be getting an updates
                    Being A7 possible when it gets it first update, OTA options maybe available which can often happen..
                  Hello
                  my new "Eachlink M6 Mini" has network issus.
                  After some minutes the network connection broke.
                  LAN or wifi... all the same.
                  I have to unplug and plug in the LAN Cable. then the network works for mor then 10 Minutes.
                    My Build Number
                    petrel_fvd-p1-eng 7.0 nrd91n 20181025 test-keys
                      Originally posted by amalek View Post
                      My Build Number
                      same testkeys as beelink gs1 and zidoo h6 pro
                      however the kernel version is different on all units
                      sad to hear.. that eachlink has issues..
                      perhaps..you could try "check rj45 port for bent metal" or "check error msgs using catlog " or "factory reset" or "reflash firmware" (if available )
                      PS..
                      I did a cool mod on my unit... with fan testing : it throttles at 50c with gov performents (anyway it got fixed )
                      cheers
                        This is one of my favorite boxes so far. This box could use an update though. I ended up relocating the internal antenna to get better speedtest results. The speed test results still fluctuate quite a bit. I may install an external antenna mod and see how that works.
                        Pros
                        Antutu as high as 57000 no overclocking
                        Price
                        3/32GB
                        Super Fast
                        Everything works so far
                        No freezing
                        No video playback issues
                        Rooted
                        Cons
                        Antutu as low as 37000
                        Screen density is 213dpi by default vs standard 240
                        No navigation bar
                        No status bar
                        Single band wifi
                        Unstable WiFi unless you relocate the antenna
                        ​​​​​​Volume is too loud
                        Gets hot, but nothing bad has happened while watching movies so far.
                        Airmouse power button doesn't wake the box back up
                        Cant find developer options unless you search in settings
                        No appinstaller app installed.
                        no screensaver
                          Found firmware
                          IMG file dated 11/13/2018. Requires Phoenix to flash.
                          Посмотреть и скачать с Яндекс Диска
                          Phoenix USB Pro v4
                          http://gsm-firmware.com/index.php?a=...=file&id=11508
                          OTA Update dated 11/22/2018
                          https://drive.google.com/file/d/1KTP...5-oNIRmRA/view
                          password: technozon
                            Originally posted by Rccm1112 View Post
                            Found firmware
                            Phoenix USB Pro v4
                            Firmware, Software, Cell-phone, Mobile, Tablet, iPhone, HTC, Nokia, BlackBerry, Box, Flash
                            password: technozon
                            Anybody test this firmware? Network issue has been resolved?
