Z69 Mini 2/16gb.. is it dead?
    Hi Guys
    Bought this box some time in Mac this year. Last month, when i power up, the box just did't want to boot. I've tried by changing hdmi and other same voltage adapter from my neighbor's box to no avail.
    There's no pin hole to be found on this box, hence unable to hard reset etc
    Any other adv what i should be looking at?
    In the meantime, i'm trying to get warranty claim from GB
    Can't seemed to find the reset button. Can't power up but not boot up
    Seek some advise
      you have to connect those two holes, in red circle, (see picture) to reset, I have soldered two pins in that holes an use a jumper wire to reset
        Interesting, you had the same problem on da same box?
          Yes
            So i just use a short wire connect those 2 holes and switch ON the power to the box, that's all?
            Hope it will not blow off the power circuit of the house
              try this tool: https://mega.nz/#%2104EDWDLQ%21EGJM1...NgjFan0fzTxQRs
              and this ROM: http://www.mediafire.com/download_re...3.84.141&ref=3
                Thank you mate! you've been patience and helpful regardless if i can revive this box. On last question, does your box auto boot up when you switch ON the power or you'll still need the remote to turn ON to boot up?
                  When I plug in the power it boots up.
                    Thanks Bruh!
                      Tell me if you succeed.
                        If doesn't work that way then you should try to short two pins on PCB with a screw driver or something from metal, see picture...
                          So i tried to flash the latest firmware using the burning tool, although it detected the connection, howver, the flash failed. Attached is the result, i'm a noob, don't understand
                          Followed the steps here https://www.entertainmentbox.com/how...-burning-tool/
                          Have yet to try the suggestion given
                            Try flashing again using an different USB port (don't use USB 3) and if it fails again attach a print screen with the error.
                              There's 2 usb port but only one was able to connect...
Name:	z69 mini burn tool error.jpg
