firmware update for two box different
hi all the forum, i have a problem with two box android and i will want upgrade to last firmware. i attach the photo of box and if possible i want instruction for upgrade, because i don't want brik. now i cannot buy another box. at the end of year i change box. i wait your reply. thanks.You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosTags: None
Originally posted by giancai View Posthi all the forum, i have a problem with two box android and i will want upgrade to last firmware. i attach the photo of box and if possible i want instruction for upgrade, because i don't want brik. now i cannot buy another box. at the end of year i change box. i wait your reply. thanks.
can you please give the Names of the Boxes , are they both 1/8GB Boxes or what ???
the Boxes are not bricked is that correct ??? you only searching for new Firmwares ???
greetings / gefattern
the second one a Scishion V88 with the same specs
Originally posted by Centro Marino View Post
Hi, the first one seems to be a MXQ 4K 1/8GB with a Rockchip 3229
Hi try to follow this guide for the scshion https://mxqproject.com/tutorial-scis...ecovery-guide/ . Just do it with patience and following exactly what they tell you. For a custom ROM you will have to research online and always recheck that the one you choose will work on your device. About the bricking the box part, it happens mostly if you don't follow instructions or don't research enough, but even if you do it could happen.
I don't understand one thing, do your boxes work? If they do and you are still not that confortable doing that yourself better leave them the way they are. Just my opinion, chees
thanks mister, for reply, but i don't want recovery... i would like change firmware....the boxes work, but they have problems with the firmware. while they are switched on, message goes out: this application has been shut down, and it also does not let me go to the playstore. if I click it does not go forward. I wanted to change firmware, but I do not want a custom rom.
Originally posted by giancai View Postthanks mister, for reply, but i don't want recovery... i would like change firmware....the boxes work, but they have problems with the firmware. while they are switched on, message goes out: this application has been shut down, and it also does not let me go to the playstore. if I click it does not go forward. I wanted to change firmware, but I do not want a custom rom.
please read the Link "CentroMarino" posted right , all you need is there linked ,
with this Guide you can flash your Box , it is not a RECOVERY , in this chase it
means restore your Box , good luck / gefattern
There are currently 1693 users online. 2 members and 1691 guests.
