Android Tv firmware on H96 pro plus 32G wisdom version
    Do you know wich firmware with ATV can be install on wisdom version?
    Yes, atvexperience works flawless. On my h96 pro + wisdom box
      Did you find a version that works?
        What version are you using? I tried the final 1 2019 & both v2ff versions. Both didn't work, theyret releasing v2h which may work
          I have try V2F and V2G.. both Version work like a Charm except chromecast & twrp
          Gesendet von meinem SM-G955F mit Tapatalk
            Did you flash via amglogic burner? I tried a few different versions of the burn tool but still get the same error
              @ Beginning i would have uboot and RAM failure. After many many trys with different amlogic usb burntools suddenly it works.
              I load first the IMG,press Start and then connect the h96 to usb.
                Thanks for the replies, tried 3 different amlogic so far. Will see if can find any others
                  Maybe you can try EyeTV ROM. It's more easy to install
