[ROM] LAKE I 2Gb/16GB - SCV1
    Hi there guys and girls, one more rom/fw for you all!
    Many thks to gearbest for sending me the device to play
    Many Thks to my beta tester trebor
    On first boot please let it sit 3/4 min in setupwizard... then you guys can start the wizard, is only to give time for the apps to install
    READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
    Changelog SCV1:
    • Lots of stuff added, updated, fixed and tweaked....
    • Enjoy it??
    Bugs SCV1:
    • On KODI 18 you need to 1º open it with a eth cable connected or else it crashes all the time, after that you can go back to wifi and disconnect the eth cable that it wont crash anymore... KODI 17.6 is ok.. so i think is a KODI 18 bug!!
    • No SuperSU app since is installation is blocked in the sdk!
    • When wake up from sleep mode the display take some time to come back... dont worry it will turn on...
    • 1º time open any app it may take a few secs, this is how this sdk work...
    • Its takes time for the wifi to get the ip.. so wait...
    • If playstore closes, dont worry its is auto update....
    • Possible lot more Bugs...
    Want to buy me a beer?
    Download:
    Install instructions:
    • Read beelink SEA instructions, is the same...
    Where to buy:
    1º BOOT MAY TAKE AROUND 6 MINUTES MAYBE LESS!
    THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
    USE AT YOUR OWN RISK!
    Enjoy it!
    No xposed (Very nice clean ROM )I test right now....
      Yep no xposed, to messy...
ID:	750087Click image for larger version
          superceleron
          Thanks a lot for providing a custom rom for this device ! Have you tried measuring transfer speed on the USB 3.0 port ? I am asking because on 107 stock firmware the max speed seems to be quite lower than what the specs provides.
          bajann
          Is the reported temperature with a hard drive installed inside the LAKE I or is the device empty?
          There is no sp00n ...
            Originally posted by sp00n View Post
            superceleron
            bajann
            Well i dint try the usb port sincei dont have a usb3 stick :/
            But i can tell you 107 fw is a mess.... im not even getting near of it!
              As found May interest a few bit cheaper than Normal
              LAKE I Home Cloud TV Box: $48.99 Flash sale amount: 200 lowest price Click for more Info LAKE I Home Cloud TV Box With its ARM Mali-T820MP3 Graphics GPU,
                superceleron would it be possible to update the firmware for Realtek 1295 boxes to Android 7 with this?
                  Yes and no, i mean yes you can and no you need to import the proper bootloader and dtb conversion from 6 to 7 etc... so without the source is a total nightmare!
                    Thanks for your reply superceleron. I have no real knowledge just wishful thinking.
                    If the equivalent RTD1295 hardware configuration file was available would the tools linked in the below page be helpful for anything?
                      superceleron
                      When trying to burn your firmware on LAKE I 2GB/16GB, when opening it with "rtk_usb_mp_tool", I got following warning :
                      "WARNING ! system.ini file flash size = 16gb. but did not find the relevant directory. please check system.ini file."
                      Please hint, how to proceed.
                        Originally posted by zzmakii View Post
                        superceleron
                        weird i never faced that problem... on what box are you trying to flash it?
                          Box is original Beelink LAKE I 2GB/16GB bought at GearBest, but problem is not in the box, it is either in firmware or in tool.
                          Using Beelink "Realtek--Android TV BOX Upgrade Tools" setup.exe (417.520.907 bytes) on Windows 7 Pro computer.
                          When tool started, choosing "Show info dlg", and checking "only upgrade firmware", then selecting flash type "EMMC_16G" and DDR size "2DDR4_2G", and opening your firmware "LAKEI_SCV1_16G_20181027.img", after few seconds it starts un-taring it, and in "progress step 41" there is info :
                          Untar file name : teeUtility.tar
                          DDRFolderDirectoryName : 2ddr4_2GB
                          Can not found ! does not install bootloader .
                          prepare usb_hwsetting buffer
                          length: 1760
                          prepare usb_hwsetting buffer done
                          then stops, and gives above mentioned WARNING.
                          Please hint how to proceed.
                            Problem solved. Flashed your firmware using USB stick.
                            • superceleron
                              superceleron commented
                              Editing a comment
                              good enjoy it!
                            Salve, quindi per Flashare la Rom SCV1 in pratica si copia "LAKEI_SCV1_16G_20181027.img" su uno stick usb
                            e aggiornare da impostazioni aggiorna locale, giusto?
                            Ma la versione SCV1 ? basata su 107 o 106 stock rom? La versione nuova della rom stock Zidoo X9S ha la app
                            HDMI_IN che permette di variare diversi parametri H264 quella prersente nella SCV1 ? uguale alla 106/107...?
                            Salut.
