Main Features
● Android 8.1 operation system
● RK 3229 CPU, quad core, 1.5GHz
● Mali 400 GPU
● 2GB RAM + 16GB ROM
● 5GHz WiFi + 100Mbps Ethernet
● Support H.265 decoding
● Support 4K Ultra HD image
gearbest
Brand: scishion Model: Model X Type: TV Box GPU: Mali-400 System: Android 8.1 CPU: RK3229 Core: 1.5GHz,Quad Core RAM: 2G RAM Type: DDR3 ROM: 16G Max. Extended Capacity: 64G |
Decoder Format: H.265 Video format: AVI,DAT,H.264,H.265,ISO,MOV,MP4,MPEG,MPG,Real 8/9/10,RM,VP8,VP9 Audio format: AAC,FLAC,MP3,OGG,RM,WMA Photo Format: JPEG,JPG,PNG Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes Power Supply: Charge Adapter Interface: AV,DC 5V,Ethernet,HD,TF card,USB2.0 Antenna: Yes Camera: Without Language: Multi-language DVD Support: No HDMI Version: 2.0 Other Functions: DLNA,Miracast External Subtitle Supported: Yes HDMI Function: HDCP Power Consumption.: 10W, 5V / 2A RJ45 Port Speed: 100Mbps |
System Bit: 32Bit WiFi Chip: 6051P System Activation: Yes |
Power Type: External Power Adapter Mode |
Remote Controller Battery: 2 x AAA Battery ( not included ) |
Product weight: 0.0750 kg Package weight: 0.3250 kg Product size (L x W x H): 9.20 x 9.20 x 1.70 cm / 3.62 x 3.62 x 0.67 inches Package size (L x W x H): 17.50 x 13.50 x 6.40 cm / 6.89 x 5.31 x 2.52 inches |
Package Contents: 1 x TV Box, 1 x Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x English Manual |
There are currently 2935 users online. 0 members and 2935 guests.
