A95X R2 Firmware?
A95X R2 Firmware?
Hi there, I have had the A95X R2 from Gearbest for a while and I was curious what the latest firmware is and what I need to install it to the android box? Also will this help speed it up at all? I usually watch Twitch steamers and for some reason 1080p @ 60fps is choppy. If I watch it with SPMC it's usually fine. I thought this was one of the faster boxes out there? I have the 2gig memory version. Thanks! Any help will be much appreciated!Tags: None
Originally posted by Justin Mainemer View PostHi there, I have had the A95X R2 from Gearbest for a while and I was curious what the latest firmware is and what I need to install it to the android box? Also will this help speed it up at all? I usually watch Twitch steamers and for some reason 1080p @ 60fps is choppy. If I watch it with SPMC it's usually fine. I thought this was one of the faster boxes out there? I have the 2gig memory version. Thanks! Any help will be much appreciated!
one of the fastest Boxes out there , really a nice Joke , first we must know what CPU is used ,
sound like Rockchip , but which , if you can post the BuildNr. of your Rom , then it is easier to
handle , is it RK3228 or RK3229 please find out , so we can move it to the right Section ,
greetings / gefattern
Number 1 rule, (and I am sure I will get some flack) stay away from Rockchip..... Most of your modern devices will play video at 4k 60fps. However, if you are an audio and video aficionado, then most likely, you will want a device that can dual boot into either LibrELEC or CoreELEC.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostNumber 1 rule, (and I am sure I will get some flack) stay away from Rockchip..... Most of your modern devices will play video at 4k 60fps. However, if you are an audio and video aficionado, then most likely, you will want a device that can dual boot into either LibrELEC or CoreELEC.
Originally posted by Justin Mainemer View PostSpecs on my box are the following:
Core: Quad Core
CPU: ARM Cortex-A53
GPU: Mali-450
Model: A95X R2
RAM Type: DDR3
System: Android 7.1
Type: TV Box
Processor: Amlogic S905W
2gigs ram and 16gig rom.
Is this your device??
The information I find about the A95X R2 , says it has a Rockchip 3328 SoC. But you say it has an Amlogic S905W SoC. Can you post a link that shows your exact box???
https://www.gearbest.com/tv-box-mini...?lkid=10813882
i checked hardware in sptv or kodi says amlogic too.
Mine is this. Looks the same too lol.
https://m.gearbest.com/goods/pp_0091...m_campaign=ord
normal it must be a RK Box , because of R2 , but the Companys dont care about that , of course your Box
must handle 4K without Problems , most the Roms are full of Bugs , if you really have a AML 905W , then
you can try the Rom of Nayam Amarshe for 905W , to find here on FT , further good luck with your Box ,
Install this app >> aida64 << and run it. It should tell you the hardware of your device, Rockchip or Amlogic. If Amlogic, there are LibreELEC and CoreELEC ports for that device, but NOT for a Rockchip device.
Read the information from this link........
Ok thanks. Otherwise, in your opinion, what would be a good box to get if money isn't too much of an issue? Something android based. What is the fastest chip or brand/model out there now?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 4894 users online. 2 members and 4892 guests.
