OnePlus 6T - In-Display Fingerprint, Smaller Notch, Larger Battery
    The OnePlus 6T aims to improve on the already excellent OnePlus 6. It utilizes a larger 6.41 inch AMOLED display with a smaller notch design that’s known as a teardrop. Another big change of the display is an embedded fingerprint scanner. The rear fingerprint scanner has been removed and the new in-display scanner lets OnePlus 6T return to putting fingerprint readers on the front of the phone. It has also improved the brightness on its displays for better viewing outdoors.
    The headphone jack is gone so that can increase the size of the resonance chamber on its internal speakers, as well as make room for a few other components without having to increase the phone size much. The OnePlus 6T runs the same Qualcomm Snapdragon 845 chipset as the OnePlus 6 and depending on the model has 6GB or 8GB of RAM and 128GB or 256GB of internal storage. Batteries was also overdue an upgrade here, it packs a 3700mAh battery that should easily make it through a day or more.
    Main Parameters:
    Display: 6.41 inches
    Resolution: 2340 x 1080 pixels 402 ppi
    Aspect Ratio: 19.5:9
    Type: Optic AMOLED (Support sRGB, DCI-P3)
    Cover Glass: 2.5D Corning® Gorilla® Glass 6
    Operating System: OxygenOS based on Android™ Pie
    CPU: Qualcomm® Snapdragon™ 845 (Octa-core, 10nm, up to 2.8 GHz), within AIE
    GPU: Adreno 630
    RAM: 6GB/8GB LPDDR4X
    Storage: 128 GB/256 GB UFS 2.1 2-LANE
    Camera: 16.0 + 20.0 rear camera and 16.0 front camera
    Battery: 3700mAh, fast charging (5V 4A)
    Unlock Options: In-display fingerprint sensor, face unlock
    Bluetooth: 5.0, support aptX and aptX HD
    NFC: Enabled
    Product Features:
    ● Screen Unlock
    Unlock your OnePlus 6T with the fastest in-display fingerprint sensor on any smartphone, setting a new industry standard with cutting-edge screen unlock technology.
    ● Display Design
    Featuring our largest display ever and a resilient glass back, the OnePlus 6T was crafted with care and purpose. Experience a 6.41 inch Optic AMOLED display for true immersion through an 86% screen-to-body ratio, beautifully slim cut-out, and more.
    ● 16.0 + 20.0MP Dual Camera
    Nail every detail night or day with Optical Image Stabilization (OIS) and our new Nightscape feature. Photos look more dramatic thanks to new Studio Lighting and an industry-leading camera sensor for better pictures.
    ● Fast and Smooth
    Do more with up to 6GB/8GB of RAM, the Qualcomm® Snapdragon™ 845 Mobile Platform, and up to 128GB/256GB of storage. Hardware and software work together for an experience that is consistently fast and smooth.
    ● Large Power
    With a 3700mAh battery, the OnePlus 6T puts more power into your hands than ever, while our Fast Charge technology gets you up and running in just half an hour.
    ● Oxygen OS
    The operating system is all about ensuring your phone works for you, not the other way around. Powered by Android Pie, the OnePlus 6T offers more features than ever on the fastest and smoothest version of Oxygen OS yet.
    ● Type-C Bullets
    Whether you’re listening to music, watching a video, or enjoying your favorite podcast, the Type-C bullets offer superior sound quality and convenience.
    The body is glass on both the front and back of the device, and you’ve got the choice of two colors on GearVita: midnight black or mirror black. That’s right: you can have any color you like as long as it’s black, the reflective choice does look quite different to the matte version. If you want bigger display with smaller notch, terrific power and cutting-edge features like the in-screen fingerprint scanner, the OnePlus 6T is made for you: https://gearvita.com/oneplus-6t-4g-s...128gb-rom.html
    Related products:
    oneplus 6t 8gb 256gb
    oneplus 6t 6gb 128gb
