Sorry if this has been posted before but I'm rather confused as to how to update it.
Mini Serie RK 3229 Android Update
Hi, I recently bought the Mini RK3229 TV Box and was wondering how I can update to a newer version of android? I've seen a lot of advice for other boxes but I'm not sure if it's different for this. I have attached some images if they help.
Tags: None
Originally posted by Alex Smith View PostHi, I recently bought the Mini RK3229 TV Box and was wondering how I can update to a newer version of android? I've seen a lot of advice for other boxes but I'm not sure if it's different for this. I have attached some images if they help.
If you flash other device firmwares to it, you risk bricking it forever if it uses a different bootloader not compatible with your device.
There is no firmware update for it.
Most likely.
You can try other firmwares but they won't work most likely and risk damaging your device.
There are already RK3229 devices with Nougat, so if it shipped with KitKat, the manufacturer already abandoned it more than a year ago.
Don't buy cheap devices with no manufacturer name on them or no website available, otherwise it will be very difficult to get support.
There are currently 2449 users online. 2 members and 2447 guests.
