SCISHION AI ONE ANDROID OREO 8.1: ROCKCHIP 3328 2GB RAM + 16GB Firmware
    https://mega.nz/#!RBsxUQAI!F5AFKGVE9...Wtv72zs8ws3HDY
    rk3328_8.1_box_RX4B_RTL8723CS_zhongx_20180822_V13. zip After you put the firmware. Just dont do a system update on your box menu. do a factory reset on your box and then do a system update. I did it like that and updated with no problem. Do it the way I tell you.
    hola antonio6o6 te querĂ­a preguntar si no hay ningĂșn fallo al instalar este firmware en el tv box .
    gracias
