A95X PLUS TV Box 4/32GB Amlogic S905 Y2 A8.1 Dual WiFi, BT4, DDR4
Let's get looking:
Box
What's in the Box: Very thin small unit.
Ports, That's it no more.
Pop the base : Note heat sink slightly raised
Casing
Remove PCB
CPU Side: Onboard WiFi Antenna, working ok, Reset Button behind SPDIF port
Other side: Not a lot here at all nothing.
Found Heatsink being raised by another component, removed and relocated back a little
As seen smallish PCB and not a bad looker at all overall
Running 32bit Android 8.1 and must say it's performing rather well
Gearbest
More to see > http://freaktab.com/forum/tv-player-...-wifi-bt4-ddr4
